One side is done , when the last fillet is dry then we do it all over again on the other side.
I was wondering how I would get the canoe to stand on it's side for that last fillet. It's a good thing there are two boats hung from the rafters on PVC Pipe , just tied off to one of them and the problem was solved.
Mick...
The edges of the fillets will still require a little sanding but the whole interior will need some light sanding after it is epoxy saturated and preped for the fiberglass.
By the way I tried one of the foam brushes , it worked but not for a long time , took two to do the fillet since the acetone ate the foam up like a kid in a candy shop.
Still have the end pours to do after the fillets and before glassing.
Mick...
