Jack,
Yes, I'll "stick" with epoxy! (Always wanted to say that.
) With the added surface area of the chine logs, I'm thinking the epoxy will most certainly keep it all together. And since I really want to do this one without fg cloth, I'll be certain to give all ply edges an epoxy seal, and probably some wood flour thickened epoxy as well, any place on the edges that I can squeeze some in.
beekeeper,
You ask the tough questions! The very ones that need answering before any kind of building can begin. 8)
beekeeper said:
Do you like the wide "flaired look", or the "no ribs look" feature the best?
Toughest one, right off the bat! Uh. . . Both? (Let me try that again.) I understand why you asked, but "Both" is almost the best I can do. It was the pictures in that thread you started, "A New Marsh Pirogue" that got me going on this. That is the "look" that really grabbed me! Now then, I know that pirogue was 15 feet long, and that simply scaling it down to maybe 12 feet could keep the exact same proportions, and preserve that "look," but could also result in a boat that is just too unstable to be a good idea.
So, I guess the idea is to reproduce that look, which is a combination of flare, beam, and length, without the ribs, and see just what length
could be squeezed out of 2 sheets of marine ply. Gosh, I make it sound so simple! :lol:
Inside chines for certain, and as for the rocker, I don't have very strong feelings about that. Not perfectly flat, I don't think, but if I really need the bow a little higher out of the water, I can just shift a little to the rear. Also, I think more rocker means more depth, and when this one will go, "skinny water" is more like "heavy dew."
I'm talking mostly very nearly still waters, come current in some parts, but pretty lazy at that. If something gets bumped into, there'd be no real impact, nothing that would require a substantial rub rail. Maybe just a 1/4 in. piece of molding on the outside, something just enough to put a contrasting stripe of paint on, mostly for looks.
Now on the inside, however, a laddered gunnel would be what I'd want, not only for the strength, but it's nice to have something to tie things to.
I kind of wonder if I stick to the the maximum length I could get with this type, out of just two sheets of ply, if I'd still need any of those bottom ribs? Maybe use 3/8 inch for the bottom? One the other hand, those bottom "ribs" do look more like battens and wouldn't really be in the way. . . I don't know.
A fixed seat? Maybe, I did see a pic somewhere of one that had a single bottom frame that was right under a fixed seat. The seat was quite low, of course, and that single rib being under it was kind of easy to ignore. But a fixed seat in a 12 to 13 foot pirogue? As narrow as a 2 sheet boat would almost have to be, I don't know that it might not be too small for a fixed seat to be a good idea. Remember, even though it would be by some people's standards, quite narrow, my balance is pretty good, and I do intend to spend about as much time doing some stand up-poling, as sit down-paddling.
In fact, I can see where it's possible I might just use one of those "throw-able boat cushions" for a seat. My UJ pirogue seat might be kind of high for seated paddling, won't know 'till I try it. One thing I can say about a fixed seat is that it would make the hull a bit stiffer.
Wow! :wink: That's about enough info to base an actual design on!
