KJ,
I can tell you what I think now, tomorrow I can tell you what I know. 8)
I suspect my notion that I would need the extra 5* angle on the stems was not only wrong, but completely bass-ackwards. It probably did add to the rocker, but I'm pretty sure that it is only part of the problem.
From watching what happened as I moved that jig into place, I'm thinking that the amount of flare to the sides had a lot to do with it. This model has the sides flared out at 35*, where I think the average swamp pirogue would have quite a bit less, more like 20* to 25*. As I moved the jig into place, I could see the ends curving up.
Tomorrow, I will make some changes, but just one change at a time so I'll know for certain what did what. I'll probably change the stems to either a 45* which is what my UJ pirogue has, or maybe take it a bit past that, and do a 40* stem. (Later on, I'll see how a curved stem changes things.) I don't want to change the flare at this time, as that is part of the difference between a marsh and a swamp style pirogue.
beekeeper,
You are quite right, I've not cut an arc in the bottom of the side panels. After I finish trying different stem angles, the side arc is next. Right now, the model is of a 12' pirogue, but with 12" sides. From what I've seen, that would be considered quite high. But I did that so I would have some height to play with. (Almost said "wood" instead, but remembered how some of the less cultured might react.
) Anyways, With most pirogues I've seen on this (and other) fourms, having 10" sides, I thought I'd first try a (1/2 scale) 2" arc, just to see how much that lowered the rocker, leaving the minimum side measurement at 10". Then, if I still need to reduce the rocker, or just adjust one end or the other, I'd have no qualms cutting the arc even deeper, where the low point of the side would be a scale 8" or so. For a 12' pirogue, I don't think that would be out of line.
Of course, this would be after the stem experiments, and if I need to, I can go back and make a change at one or both stems to dial it in. Like I said, just one change at a time, until I better understand what each change will bring. And at least for right now, I think I'm going to keep it more-or-less symetric. Might be wrong, but I *think* that it might be more important on a larger boat, anyway. (As usual, could easily be wrong!)
seedtick, (if you made it this far, I mean. . . )
Understand about two jigs giving a fairer curve, but I have to ask, when using two like that, should they both be not quite as wide as a single jig would be? Instinct tells me that would be true, otherwise I'd expect a straight line between the two jigs, and don't think the wood would let that happen. On the other hand, this does fall under the "easy enough to try out" category. Just the reason for the 1/2 scale model to begin with.
tx river rat,
How you doin' Ron? Nice to hear from you. I think I've seen this one before, not just because it's a great looking one, but also because it's sitting on a doggie crate!
Thanks for the info, but let's see if I really understand what you did there. . . Sometimes, I'm kind of thick. . . Actually, now that I try to ask, I realize I really don't quite get what you said.
Or, maybe. . . Did you cut a 3" arc in the bottom of the side panel, and then cut a 2" arc in the top of the side panel? No, I don't think that's what you are saying, as I think that would put a lot of rake in the deck. (What I used to call it when a boat had high freeboard fore and aft, low freeboard midships.)
Ron, can you give that explanation another shot? I promise I'll pay attention this time!
Much thanks, everybody! 8)
beekeeper,
tx river rat,
