Captaindoug posted a link to the 1948 film "The Pirogue Maker" and it just happened that friend Keith and I are currently involved in a remake documentary of that film. We'll be using similar tools and techniques shown in the film and we thought some of you might be interested in the project.
To build a dugout, you have to start with a log. In 1948 they cut a tree down, today you have to pull up a sinker.
Look around at the pile of logs left over from last summer's work
pick one out, cut off the end. I included this just to show the shake or split that shows up in many logs. It's the result of a centuries old hurricane that came through, didn't blow the tree over but did create an internal shear that the tree eventually grew around
cut out a section, split it down the middle, get friend Keith's approval. The shake will often run quite a ways and since it is a weak spot, we will avoid it in our build.
put it on the trailer. This log is 12 feet long and 40" across and it has about 80 growth rings per inch.
