Hey guys, I need some help. Some water worked its way between the rub rail and the plywood side. The glue started to fail which allowed more water to enter. I now have a soft spot of ply abut 3/4 inch in diameter adjacent to the rub rail and the rail is separating from the boat in several spots. Can I fix the problem by sanding the paint/ epoxy off, letting the wood dry, reattaching the rail with epoxy, and then glass and epoxy like hell to strengthen the spot? I did not originally glass the rub rails but plan to do so now. Note to self "do not use tightbond II to build next boat use epoxy".
Thanks for any advice.
Tom
Tom
