I have found a knot that is ideal for the rain fly's on the hammocks if you tie them off to trees , scrubs or anything even the ground and then it could be used to keep the lines tight if the rain fly sags. It would be ideal for tarps , to keep then tight. It is a simple but very effective knot and is easy to untie when breaking camp.
The beauty of it is that after it is tied then it can be adjusted without un-tieing the knot to adjust the tension on the line.Just slide the knot where it gives the tension you want on the line.
Based on Rolling hitch #1734, this version is the one most often seen named Taut-line hitch, commonly in non-nautical sources. It is the method currently taught by the Boy Scouts of America.
Borrowed this picture from .... wikipedia/
1. Pass the working end around the anchor object. Bring it back alongside of the standing part and make a half-hitch around the standing part.
2. Continue with another wrap inside the loop, effectively making a round turn around the standing part.
3. Complete with a half-hitch outside the loop, made in the same direction as the first two wraps, as for a clove hitch.
4. Dress by snugging the hitch firmly around the standing part. Load slowly and adjust as necessary.
