Bently said:
Thanks guys. Another quickie if ya don't mind. I want to double up my seems inside and out. I have some fiberglass tape I'd like to do all the seems with. Then or before lay my solid cloth? Does that make sense? I guess my question is should i for example lay my solid piece on the bottom finish it then lay my tape on the seems or tape first then big piece? Thanks in advance.
On the butt joints I use left over glass and run it about 3 inches ( Or More) on each side of the joint. Keep in mind ( As you said ) that the joint will be glassed over when the outside of the boat is glassed and when the inside is glassed so there is double glass and epoxy over that joint.
The tape will work for you if you are careful on the joints and run the epoxy saturation out a ways on each side of the tape just as a additional support for the wood....... Then when it is together glass it and the boat and you will be safe. I say that since I have no idea of the width of the tape you have , the wider the better. Especially if you are going to have some of it on the front or back or all along the center seam of the boat where all the abuse is offered to it when paddling and the tape is designed for those areas , to beef them up.
Depending on which boat you are making.
Main thing is how much glass do you have and can you spare a piece of it or have to use the tape to do the job........ It is really nice having some left over glass form the last build. Most of the time on a normal build there is left over glass from the front and back of the boat since it is a cigar shape and not a box. You know pointed in the front and back and wide in the middle like a lot of us Geezers are. :lol: , Not you young guys.
That tape is for the boats with a "V" or semi "V" bottom , OK.. A Pointed and not flat bottom boat , the Pirogues it is normally along the edge since that is where the wear and tear is to them.
If you use the tape , do not forget that ridge along the one side of it , it will need to be removed to have a nice slick surface when you glass the boat if you use it on the joint.
PS. Any questions ... Please ask ... we can help you miss ( Bypass , Skip ) all the mistakes we have made and later you will help folks asking questions. That is why you and all of us are here......
