We're getting there, slowly but surely. The last couple of days has been a good bit of work but not much visible progress...I rounded over the edges of the ribs and sanded them a little, then routed some notches in the bottom so water doesn't pool in the bottom sections between ribs.
We also got the ends cut and pre-drilled holes in the ribs, stems, and sides where everything gets screwed together. Somehow the long dimension of the sides ended up at 16 feet, 4 1/2 inches...I guess okoume sheets are longer than 8 feet.
Hopefully tomorrow we'll get the stems & ribs screwed into place...then I'm going to be shut down for awhile figuring out how to fabricate rubrails that are long enough for this boat.
