SLIDING PIROGUE SEAT
80
Sliding Pirogue Seat
My seat in the concave (inverted V) bottom pirogue sometimes would slide off center, and it was hard to get it back to center while I’m sitting on the seat. so I thought two ¾ “ sticks on the bottom would keep it centered.
I decided that was too simple, and went for a sliding seat. I used a seat base I already had, and put two “runners” on it so it wouldn’t rock on the apex of the inverted V floor and used UHMW tape to make them slicker.
SEAT BASE RUNNERS
PLU3Jz5a6sc4JZeHpakZ6COaH2NHYcOJ6b9I1rX1NXQIMb45HMkucrcCkuBrC5V4mGIYEb7UbnDmJHgvJ1bwpuqc-PZXiZYWUEuaJ4O9wrS5L_0mqK6y65uj-XvxME5QfQr08jRg
Two ¾” cedar were used to keep the seat centered, one was drilled to accommodate a bolt latch to lock it in place.
SEAT GUIDES
1AWpbqyY2uhqej_xSPNjTgLmYcJ34I-yaYVFH8yr7IvwYcr573TJf9hIVwuj8DwiuWZTGsM8hfCJz620FHx_fbYonD7B591urb0m38A5N_6176kYbtdUgkhiC7tysUvFArU2eFUU
LATCH BOLT
nWFD3rRHSEze_8asknL6IxagqSgf8NhWomc8SHugCelJuNMpHzT7oFWUvklg1pucyndFn6I4TRdroR9eQ3H8hnzN5sp7PQFXi8F7OmsLVFcmnTJ9PIz583DUSBG4Dm4e2GROYFtu
FINISHED SEAT
KqTN-ZMgsCBGeeQpdYg3IaChCTQHT255dKjgn35Do1hnJsjS8ZpjqaKyfr7uGGUtiLd4G9Ql_jQ0NLMLUCKVJ-W1upRRYabIfxk1JZY_IqzpHls5P774DinwsRCZCHqUAvDGToJe
I like to keep things simple, but this addition makes it easier to keep the seat where I want it.Beautiful day in Kansas, especially for December.
Good Fish’n
Andy
58
I like your set up. The latch is probably a wise addition.
I once had a cushioned seat that I fixed to swivel. Worked well for casting but tended to rotate back and forth while paddling, not good.
A built-in bench seat would be the simplest, but not very comfortable. Everything about boat building seams to be a compromise.
