serious boatbuilding questions | Page 2 | SouthernPaddler.com
crazycajunmike said:
what wood filler to use if any ?
you can use epoxy thickened with woodflour (fine sawdust). If you're trying to color match, experiment because the mixture color will be darker than the wood. You could get some cabosil filler (white) and do a blend of that and pine woodflour to lighten the color.
stain any type as long as it is water based ?
yep
Next cutting stem/stern and ribs........Can I use oak ? Any problems with epoxy or fiberglass sticking to oak ?
you can but oak tends to split easier over time. Not saying that it absolutely will. Ash or spruce are also good choice.
When I made mine and during the sanding on the panels I got a ton of wood flour. If you sander has a collection bag on it , that is some good wood flour to use on the boat. Just put the flour in zip locks.
Also got a lot from the sawing but had to sift it to remove any chunks.
