Boy this is getting deep. We all learn a lot from these type conversations.
I have been staying up nights worrying about this :roll:
Dang here we go, first I have to say I think most everything said on this subject is right.
Chuck the wood is important , but can be built around any imperfections,Jack good wood is awesome to work with but not a necessary thing .
Every ply you add srengthens more than just the thickness of the ply
Here is my thoughts on the epoxy saturation, yes it helps much stronger,
Ok here is why to me , you have a plywood with three plyes in it which makes it stiffer, epoxy saturation adds another ply, to each side ,now you have a 5 ply piece, then you add another layer and then glass cloth now that is two more plyes to each side so you have a 9 layer ply or a composite, if you could slide the wood out of this composite it would still be strong. Fiberglass boats have no wood in the hull as we use it because they have a mold to hold the shape, they just shoot the resin and chopped glass in the mold let it dry pop it out a good serviceable tough boat
If I was building a boat and just painting it , nothing added to the structure for strength it sure wouldn't be 3mm ply it would be timber that was solid like Seedtic and Kieth use.
If I want a tough boat that is light I use ply and epoxie and glass cloth to build it (I really use polyester cloth and wood :lol: ) and it works. If I am using laun there is more care taken to make sure there are no voids ,with marine plywood I do the same inspection.Adding the soaking coat and the other layers you are not going to hear a cracking noise, unless you built the boat wrong and both woods will break.
My two cents
PS maybe I can sleep tonight now :wink:
