I was wondering, Seedtick mentioned the fact the rocker in the stern will be less than the bow because the stern isn't being pinched in as severely with a square stern. If I were to put more angle on the transom than the ribs, would that get some of that rocker back?
Is that even that important? I was concerned about the drag caused by the square stern, thinking the rocker might keep the transom up higher in the water, causing less turbulence as the boat passes through the water. Of course everything is a compromise, by making the transom pinched more I lose some of buoyancy I squared the stern for in the first place. Any thoughts or comments about this?
