OK I've recently discovered that I can bend 4mm ply, now I now that doesn't come as a surprise to some but I was surprised. A little heat and gentle persuasion allows some fairly tight curves.
Now my problem is 4mm is still not very strong so I need to bend a few pieces and stick them together. now if I want to make this as strong as possible I'll put 6oz glass between each lamination and on the outside, but that seems excessive.
I do apologise for the post below but it's the closest I can come to illustrating what the aim is.
the supports will be 1 inch wide and need to support 100kg (maybe a bit more if I invite my larger friends to sit down...
). Am I dreaming do they need to be wider or more layers?
Or is this going to be a trial and error experience for me...?
It's for a canoe seat that I can remove for a fishing/picnic seat
Tor
Tor
