After washing and drying the pan really good to get any manufacturing oils off it. I seasoned the pan with some Coconut oil , did this three times just to make sure I got it seasoned. Heated the oil to the smoking point , then let it cool down and cleaned the pan with a paper towel. Set the pan aside for a couple of days.
Next.......Clarified Butter ( Ghee )
I took some butter and clarified it so it can stand a higher cooking temperature since the milk solids are out of it. It's the perfect thing to use for frying if you want a good rich butter taste to your food. Plus it is idea to take camping since it will last for days. Unlike sticks of butter that need refrigeration the Ghee can be without refrigeration while you are camping. Here at the house I keep mine in the frig.
Whipped up a couple of eggs in a bowl and added some salt and pepper.
I put the pan on the stove , turner the burner on to medium low and let the pan warm up for a couple of minutes. ( This is the trick to help make Stainless Steel pans stick free )
After it warmed up I dropped in about 3/4 teaspoon of the clarified butter ( Ghee ) and let it melt. Next step was to swish the Ghee around in the pan to make sure it was coated. Added the beaten eggs to the pan and let them cook.
I could take the pan and move it and the eggs would slide around without sticking. It was like the omelet ( eggs ) was floating on air. When the sides looked cooked I flipped the omelet so the other side would get done.
Added some good extra sharp shredded cheese to the top of the omelet while it was cooking
When the omelet was done I held the pan over my plate and angling it to about a 45 degree angle , the omelet slid out and onto the plate. When about half of it was on the plate I moved the pan up and forward. The other half of the omelet folded over it covering the bottom half and the cheese.
Next step was adding some Spicy Salsa to the top of the omelet and rounding up a fork.
Cleaning the pan was a breeze , ran a moist paper towel around the inside after it cooled. This pan will not see any soap and water , just a re-seasoning now and then.
Yep ...I'm Happy with it.
