Decided to give it a look since I am close to starting it ... The seats are sitting on the top , they will be 4 inches lower and 8 inches from the bottom of the skiff.
The center seat and the Redwood block on it is one of the supports that will be on the sides for additional support for the seats. That piece of wood under there ( next to the scraper ) is the templet I will use to get all the redwood blocks set at the same height , it fits against the bottom of the top inside rail and the top of the block is against the bottom of the templet.
The position for the rear seat which will be just behind the ribs.
The position for the front seat , just in front of the ribs ....... If you noticed it has a smaller area to sit on then the other two...... This way I can adjust my weight in the boat and the passenger ( If and when I have one ) is stuck in one spot. :wink:
Now to do some dry fitting , cutting and matching everything up so it fits just right. Then some epoxy on the sides and when it has cured , some more on the back of the blocks and clamp them in place ...... when everything is in position then drop the seats in and epoxy them in place , fillet all the edges , sand and varnish.
Like I said , It's a good thing I have the time to do all this so there is no rush on getting it done.
