It might be a bit premature, but this is my "Glades Skiff build thread." I put that in quotes, because I've only gotten most of the materials together, no actual building yet. I only thought I knew where I was going to pick up the plywood and cypress planks and as a result, spent a couple of extra hours (and miles!) finding things. Oh well, at least I got them. . .
I intend to follow the design and instructions given by Glen Simmons in his book, Gladesmen - Gator Hunters, Moonshiners, and Skiffers, as closely as I can. When I do wander away from the original, I'll point it out and explain why I did it. The few variations I make should not alter the looks of the boat, hopefully it will be close enough to be considered at least a "visual replica." I'll also include the cost of materials so when I'm done, we'll all know just what the finished product cost to build.
I will also be cross-posting much of this to my new "other home Forum," BladesAndBushcraft dot com.
First off, I drove up to Homosassa, FL, to get 2 sheets of 1/4" fir marine plywood. The fir is more rot resistant than Okume, and much less expensive. $44 a sheet, for a total of $93.28 including taxes. Then it was a drive down (and around and around, since I forgot where it was, to Land O' Lakes, where I eventually found Crossroads Sawmill & Lumber Yard. Here, I picked up 3 1"X10"X14' cypress planks. Those were $15.75 each. Also got a 2X4 too see if I can turn out a paddle. ($5.34) This totaled out to $56.28.
Total spent on the wood was $149.56. I'll may adjust that down at some point, as the 3rd 14' plank will likely only be less than half used on this build, the rest will be used on another build later on. And the 2X4 is really for an experiment in paddle building.
"If there ain't a picture, it didn't happen!" is something I've heard before. So here you go:
By the time I got the planks home today, I was due for an on-line software coding lesson from my father, and when that was done, the rain started. So, looks like I'll have to get the actual building started in the morning. This is going to take longer than I though, as the planks are rough cut and a little "green." But sitting in my garage, they should dry out fairly quickly. And the moisture content really has to come down a bit before I can do much with them.
I'm not sure, but I think my next door neighbor has a planing machine. I hope so, and I'd like to plane the thickness of those planks down. Otherwise, I'll have to at least smooth them down, being rough cut, the hard way. We'll see.
In any event, the first step will be to cut the two plywood sheets down to size and shape. Then the sheet with the bow will go into a waterlily pond to soak so that I can start bending the bow into shape. That what I want to get started in the morning.
Well, the thread has now been started, only have to get the build started to match it! Feel free to post comments any time the mood strikes you.
