Here is my 1377 converted to a 1322 with longer .22 caliber pellet barrel, better pumper grip along with black pistol grips. I put a red/green holographic sight on it also for my older eyes. :mrgreen:
14.5 inches. The 1377 barrel is 10.25 but there are no longer any 1322 barrels being made. ETrhutchinson said:Thanks, I may take you up on that. How long is the 2289 barrel ?
Richard
Yes but if you do not want to mill the end or drill the holes just buy a 2289 barrel and install. You could cut it shorter and just crown. Either way you can make your own 1322. ETTom @ Buzzard Bluff said:Altho the 1322 barrel is NLA the 24" .22 cal. barrel from the 2260 rifle is readily bought from Crosman----enough for 2 10.25" barrels with a bit left over.
wilded said:Yes but if you do not want to mill the end or drill the holes just buy a 2289 barrel and install. You could cut it shorter and just crown. Either way you can make your own 1322. ET
