Does tight weave wet out clear like regular weave fiberglass cloth? | SouthernPaddler.com
Outdigenous
8
My only fiberglass cloth experience is with 6 oz regular weave from RAKA. Wondering could I get the same transparency with the 3 1/2 oz tight weave. Mr. Chuck, do you leave your boats mostly clear, or painted? Thanks.
I use the 3 1/2 tight weave from RAKA and it comes out clear. Most of my boats were clear but the bottoms were graphite and epoxy mix which is Black . I did use some Teflon epoxy paint that was white on a couple others.
Here is a link to Matt's web site , JemWatercraft and the 14 foot Sasquatch I made. It has the white Teflon paint on the bottom and up to just past the water line.
( The 14 was from a kit with the wood furnished , the other was a Pygmy Coho Kayak , also with the white bottom. )
Here is a article my youngest daughter posed that shows the Kayak and even a 16 foot Uncle Johns Pirogue I made from 144 red wood strips.
Reactions: Outdigenous
81
After reading about Chuck using 3.5 oz to build light weight, I used it on a uncle john type with luan. It iseasy to work with. I like to use it on decks and other places besides the hull. I especially like it over graphics. Last time I tried to order it RAKA didn't have it.
Outdigenous
8
Thanks Old Sparkey for confirming the tight weave's transparency AND the pics of the boats, they are beauties for sure.
Outdigenous
8
Thanks Old Buff Pilot.
I'm wanting to try the 3.5 tight weave not only for saving weight but also expecting a bit more panel stiffness. I hope RAKA has it again when I order, it is on the store website as if they do have it.
My youngest watched me take the kayak for it's 1st run and when I was paddling back to shore she looked at me and asked , How is MY BOAT doing. Right then I knew I had lost the kayak to her , it was just a matter of when.
I liked the tight weave since it is easy to work with and offers lighter weight and the extra protection of a ( Normal ) heavier weight glass , a winner all the way around.
