I'm wondering if any of you southern builders have experimented with spraying 2-part automotive clearcoat—rather than spar varnish— on cedarstrip boats to protect the clear epoxy from sunshine.
I'm a canoebuilder in northern Wisconsin and I've been experimenting with a common PPG automotive clearcoat, applied with an HVLP sprayer, on my cedarstrip canoes. I've seen very encouraging results so far in the way the coating protects epoxy from UV degradation, but we don't have the intense sunshine up here that you southern builders experience. 8)
Anyone using sprayed automotive clearcoat in place of the traditional five wet-sanded coats of spar varnish?
If the finish holds up for several years to Florida sunshine, I'd consider that the acid test!
Gary
When people finally figure out what's important in Life, there's gonna be a big shortage of canoes.
Gary
