Last summer I built two matching U J Pirogues concurrently. When they were done I found that they nested really nicely.
How about this.....build a U J Pirogue, but without the varnish for now.....then just off the middle point add two light, strong divider bulkheads, about one saw-blade thickness apart. Fit them in after all other glassing, etc is complete, epoxy them in, fillet the exposed sides, glass tape, etc. Mark and drill 4-5 places through both of them together for 3/8 " bolts with rubber gaskets and big wing nuts. Then cut the boat into two parts between the bulkheads. Epoxy the raw edges, and finish varnishing, etc. If done in the right spot this should give one half that will nest into the other half pretty well and fit into many SUVs, light trucks and even condo's and apartments, dorm rooms, etc. Seems to me if the bottom and sides were joined well and "happy" as one unit, they won't change as two units as long as the bulkheads are solid.
Pretty tempting idea. If Jack had a Pirogue we could experiment with it.
Piper
Piper
