An Italian workman wants a job, but the foreman won't hire him until he passes a little math test.
"Here's your first question," the foreman said.
"Without using numbers, represent the number 9."
"Withouta numbers?" the Italian says.
"Datsa easy." and he proceeds to draw three trees.
"What's this?" the boss asks.
"Ave you gota no brain? Tree and tree and tree
makes a nine," says the Italian.
"Fair enough," says the boss. "Here's your second question.
Use the same rules, but this time the number is 99."
The Italian stares into space for a while, then picks up the
picture that he has just drawn and makes a smudge on each
tree. "Ere you go."
The boss scratches his head and says, "How on earth do you
get that to represent 99?"
"Eacha of da trees is a dirty now. So, it's dirty tree, and dirty
tree, and dirty tree. Datsa a 99."
The boss is getting worried that he's going to actually have to hire
the Italian, so he says, "All right, last question."
Same rules again, but represent the number 100."
The Italian stares into space some more, then he picks up
the picture again and makes a little mark at the base of each
tree and says, "Ere you go. One hundred."
The boss looks at the attempt. "You must be nuts if you
think that represents a hundred!"
(YOU'RE GOING TO LOVE THIS ONE!!!!)
The Italian leans forward and points to the marks at the
base of each tree and says,
"A little doga come along and shita by eacha tree.
So now you gota dirty tree and a turd, dirty tree and a turd,
and dirty tree and a turd, data makes on hundred."
So, whenna I start?
tree. "Ere you go."
So, whenna I start?
