I've built two in the past, both 20 years ago and not worth salvaging, and am getting ready to start another for small water fishing. While not wanting a barge stability over speed. Generally speaking how might I address these aspects?
Rocker? Previous builds both had around 4 inches total. Will reducing this to 2 increase or decrease stability? I could see it going either way. At 185lbs the bow and stern did set in the water with the 4in. of rocker but not by much.
How wide at the gunnels is too wide to paddle solo effectively? Previous was 32 inches, thinking about trying 34. Even wider? (I'm 5'10")
If I go wider am I better off increasing bottom width or flair? Combination of both? Previous had 24.5 inch bottoms and it seems that many pirogues have much less flair then my previous builds. Is their a preferred midship angle? Not worried about just using 2 sheet so I can make the bottom wide if it gets me what I'm looking for.
THANKS!
THANKS!
