After too much procrastinating, I have started building a close-as-I-can-get-it replica of Totch Brown's Pit Pan. It was basically a small utility boat that could be hauled overland from one body of water to another when needed, by one man. This means it was good for exploring and hunting (legal and otherwise.) Totch said too many asked how fast a boat could go, when they should have been asking how fast could you build it.
Near as I can tell, what makes this different from a jon boat is the bottom curves up at both ends. The jon boat typically curves up a bit at the bow, with the stern being plumb. This works well for outboard motors. But this boat was meant to be poled when possible, and paddled in deeper water. So it has that "rocker" at each end. In this case, 3 inches at the bow, 2 inches at the stern. But the rest of the bottom is flat as a pancake.
Not a good pic, but it is Totch in a Pit Pan.
Got started earlier this week, beginning with some new saw horses. Been needing these for quite a while!
Got a little too clever, decided not to waste any wood, and rather follow the instructions I'd found, I cut each of my 2X4's into 3 equal pieces. Once I got the first one put together, I found out that 32in legs make for one tall saw horse! I cut the first one down to size, and shortened up the legs on the second one before putting it together. The cut pieces on the ground show how much I shortened the legs.
Next, I cut out the bottom and the sides. In the pic below, one of the sides is laying on the bottom panel, and you can see the chine has been clamped in to place, so I could check the bends and mark it to cut the ends.
The chine logs have a bend near each end, and I had to make a saw cut 3/4ths the way through the chine at the bend, so I could make the bend without breaking the chine. When the hull gets turned over, those saw cuts will be filled with thickened epoxy.
The chines were laid down on the side pieces, buttered up with epoxy and put into place. A few finishing nails held the chine in position so I could turn the side over and drive in the ring nails through the plywood and into the chine. Once done, those finishing nails were removed. This is how I saw seedtick and Friend Keith attach the chine logs in their Marsh Pirogue build pictures. Thanks, guys!
In the pic above, you can see I've also fitted the bow and stern ends. And guess who thought he had 12in wide cypress planks? Turns out what I have on-hand is a nominal 10in width. So, I'll have to piece the rest together, later on. No real problem, the way the boat goes together and gets finished, you'll never see it.
Have to let this go for now and get back on it, next Tuesday. Just too much other stuff I have to get done. (Such as mowing that grass!
So for now, I'm just pre-bending the bottom panel and figuring out how I'm going to get this back into the garage.
This should have been a fast, easy build. But I'm finding myself moving very slowing in the 92*F heat! Not complainin', just explainin'!
