My daughter needed a paddle. So I had some scrap wood and took a few months and built one for her.
The shaft is ash.
The two strips on the blade are cherry
The dark wood on the shaft is mahagony
and the handle is a combination of ash, cherry and mahagony chunks.
I glued the wood together with Titebond III wood glue. Once it was all set, I planed away everything that was not a paddle. Once again, my favorite plane is a little thumb plane. You can feel little bumps and ridges when you have that plane in the palm of your hand.
The blade shape is based on my trusty Grey Owl.
The blade is wrapped in 3.25 oz glass set in epoxy. Then the rest of the paddle is covered in 3 coats of spar varnish. I am not happy with the finish and may add three more coats of varnish.
Next project is my pirogue. I have a new router/ table and am working on the ribs now.
till next time!
Pirogue
The shaft is ash.
till next time!
Pirogue
