Clarified the Butter........ | SouthernPaddler.com
Clarifying butter.....
I have always done the melt the butter then drain threw cheesecloth and repeat the process ...with more cheesecloth .... this one seams a lot easier and simpler.
I like the totally clarified butter for camping since it does not spoil since the milk solids are removed , it also does not have the tendency to burn when heated to a high temperature ... as in doing blacken fish or any other foods. The local grocer had a two for one special on the Land "O" Lakes Butter so I loaded up and to save it past the due date ..... I clarify it.
Click on this of just skip it and read what I copied and posted.
www.cookingforengineers.com/article/131/Clarifie
Clarifying butter is as simple as melting butter and letting the milk solids settle or rise out of the fat. Care should be taken not to burn the butter while heating it, so use a heavy pan that doesn't have any hotspots (see Common Materials of Cookware for more information on hotspots). When using salted butter, it is difficult to guess how much salt will remain in the clarified butter. A lot of the salt can be found in the milk solids as it settles or foams up, but the exact amount will be different every time. Use unsalted butter to remove any uncertainty (you can add salt to the clarified butter later to achieve the desired saltiness).
To make approximately 3/4 cup of clarified butter, melt one cup (225 g) of butter in a small saucepan (a 1-quart saucepan is shown in the picture) over low heat. With a good saucepan, you can just leave it there over low heat while doing something else and the butter will slowly melt. Turning up the heat will melt the butter faster, but the milk solids may begin to burn, so, resist the temptation. Instead, you can cut up the butter into pieces to speed up melting. Also, if you don't have a small saucepan, it may be best to use more butter. Too little butter in a large diameter pan will make it difficult to separate the solids from the fat later.
When the butter has completely melted, continue to heat it over low heat. Some milk solids will drop to the bottom of the pan while others will rise as foam. As the milk solids rise to the top, they can be skimmed off. (Or, it can be removed when the butter cools.
At this point you can remove the butter from the heat and skim off all the foam. Let the butter cool a bit to let more of the solids settle and then pour or spoon out the clarified fat, leaving the remaining milk solids in the pan.
Alternatively, pour the hot melted butter through cheesecloth to filter out the foam and solids that have settled, catching the clarified butter in a jar.
Or, pour the hot butter into a container, allow it to separate while cooling and then refrigerate. After it has solidified, you can easily scrape off the hardened foam from the stiff clarified butter layer.
Although pure clarified butter does not need to be refrigeration, I recommend you store your clarified butter in the refrigerator (some milk solids may still be present and may cause the butter to go rancid). Use the clarified butter as you would use regular butter (tablespoon for tablespoon) in recipes.
Additional benefit of the clarified butter. A couple of them.........
Robert Wolke, in What Einstein Told His Cook, suggests using the left over milk solids for topping popcorn. Sounds like a good idea to me!
(Also, Wolke mentions that no lactose is in clarified butter, so lactose-sensitive individuals should be able to enjoy clarified butter without the uncomfortable effects those of us who are lactose intolerant are well aware of.)
Uncle Chuck, some of us lazy SOBs drop over to the local Albertson's Grocery and buy "ghee" , in the middle eastern foods......someone else had the fun of doing all the clarifying.
I think one of the presidential hopefuls has promised to use federal funds to develop cows that give clarified cream.
Piper
I let someone clarify olive oil. Extra virgin type from very quick stepping trees.
YO .... Jack.....
We are talking about Butter here , olive oil is usually filtered before bottling but it doesn't have to be , manufactures choice.
The reason is quite simple , most manufactures use centrifugal force to extract the oil from the pore olive at about 6,000 RPM. Can you say .... Dizzy olives but they don't care they were crushed before hitting the merry go round.
Plus the virgin (younger trees) don't produce olives , it is the older trees that play around with the bees and bugs that produce the olives.
