I assume that some kind of anchoring system is going to be pretty vital for pirogue fishing. It looks like many (most) use some kind of trolley. I have to wonder if some of the systems aren't a bit overbuilt and/or overengineered for the kind of use they will see on most pirogues. I am assuming generally sheltered conditions, shallow water, and not very fast current will be the typical usage. Otherwise I'd choose a different boat (I own a canoe as well).
So with that in mind it seems to me as if nice pulleys may be purely optional. I am wondering why a system that amounted to a couple loops of paracord through the same holes as the bow loops with rings on them instead of pulleys wouldn't be adequate. I figure that to start with I could try using rings cut from pvc pipe instead of pulleys. They might wear out too quickly, but if so they'd at least serve for a test of proof of concept.
I recall seeing a diy cleat made of pvc pipe that might round out this low cost setup. The whole project could probably be done with stuff on hand.
What do you guys use for a trolley if you use one? What kind of anchor? I'd imagine something pretty minimal would be okay. It might even be nice if it was easy to drag it intentionally.
